• 400 views | 3 messages Discussion: LEAP
    Topic: no 'environment' in the result Subscribe | Previous | Next
  • Kong Felicity 8/22/2014
    1600 Views
    hello,
    I encountered a problem.Though I've added the Environmental Loadings by TED, still can't see the 'environment' in the result.
    -Ella
  • Taylor Binnington 8/22/2014
    1600 Views
    Hi Ella,
    You also need to instruct LEAP to save those results. In the main menu, go to General: Results Variables to Save, and ensure that each of the environmental results that you want have been checked. The next time you view Results, you'll be able to see environmental results for your area.
  • Qiang Tu 8/23/2014
    1584 Views
    Great - Same problem solved.
