• 562 views | 3 messages Discussion: LEAP
    Topic: Lots of Errors in every action in LEAP Subscribe | Previous | Next
  • Yuta Ikeya 9/27/2014
    1559 Views
    I have installed LEAP for my course and I am now dealing with Exercises.
    At first time I installed it on my computer, it gives me error everytime I click somewhere such as confirming of setting parameter, making new directly, etc in the middle of my work.
    After that it continues keep showing errors and there was no way other than shut LEAP down.
    I tried re-install of LEAP but nothing has changed.
    I have sent error reports but I couldn't receive any answer so I gave it up and uninstall it and delete even the data in my Documents/LEAP2011 Areas.
    After trying this, I reinstalled LEAP again but it gives different type of errors from last time and I can't send report for these errors this time.
    The errors always begin with
    "NexusDB: nxDatabase: Table does not exist. Error opening files..."
    Any help?
    My setup
    User Name: Yuta
    Version: 2014.0.1.14
    Microsoft Windows
    Version: Windows 7 (64 Bit)
    Windows Directory: C:\Windows
    Running as: Standard User
    BDE Installed: Yes
    Excel Installed: Yes
    Word Installed: Yes
    PowerPoint Installed: Yes
    Running within Wine: No
    Screen Resolution: 1366 x 768 pixels
    Date Format: yyyy/mm/dd
    List Separator: ","
    Decimal Separator: "."
    Thousands Separator: ","
    Internet Explorer: 10.0
    Fonts: Small fonts (100% Scaling)
    Computer
    RAM: 4096 MB
    CPU Manufacturer: GenuineIntel
    CPU Type: P 6
    Number of CPUs: 4
    MAC Address: F6A5D03325AC
    Disk Size: 255.7 GB
    Free Disk Space: 55.8 GB
    Connected to Internet: Yes
  • Charlie Heaps 9/27/2014
    1519 Views
    Sorry for the problems and thanks also for posting the system information - that is helpful.
    I see from this information that you are running as a standard user, ie you do not have administrative rights on that Windows account.
    As you may know, you need to have administrative rights to initially install LEAP. But once installed properly, LEAP is designed to run LEAP under a standard user account. However, the error message you note does seem to be related to some files being inaccessible, which could possibly be related to not having administrative access rights. At this stage I'm afraid I cannot be more certain.
    So at this stage I would suggest trying to run LEAP with administrative access rights if that is a possibility for you.
    Please also note that I have just posted a new version of LEAP that does fix some bugs (2014.1.17). Please test that new version to see if it helps.
  • Taylor Binnington 12/10/2014
    1379 Views
    Hi Yuta,
    I wanted to draw your attention to the following post, which I think pertains to the problem you're experiencing:
    http://www.energycommunity.org/default.asp?action=9&read=3184&fid=22
    We hope these suggestions are useful for you. In the meantime, please also update to the latest version of LEAP (by clicking Help: Check for Updates), which has improved internal error reporting capabilities.
    Thank you,
