• 379 views | 3 messages Discussion: LEAP
    Topic: Environmental Loadings Subscribe | Previous | Next
  • Richard Byrne 9/27/2014
    1490 Views
    Ive run into trouble with the Environmental Loadings part of a project. I can't seem to produce a graph of the Global Warming Potential after entering the different IPCC values for each fuel in the Demand sector and the Transformation sector.
    If anyone has any insite into why I can't obtain the graph in the results page that would be great.
    Cheers
  • Taylor Binnington 9/27/2014
    1489 Views
    Hi Richard,
    To make sure that I'm interpreting your problem correctly: when you click Results, can you select any Environmental results from the drop-down menu?
    If not, please also ensure that you have enabled the saving of environmental results (even if you have enabled Environmental Loadings in Basic Params), by clicking General: Results Variables to Save from LEAP's main menu in Analysis view. Note that these results are now saved by default, in the most recent version of LEAP.
    If this does not address your problem, can you please provide more details (i.e. your version of LEAP, as well as an exact set of steps to reproduce the problem that you see)?
    Thanks very much,
  • Richard Byrne 9/28/2014
    1486 Views
    Thanks Taylor this worked
