• 253 views | 2 messages Discussion: LEAP
    Topic: the unit of energy intensity Subscribe | Previous | Next
  • ZHAOJUN REN 10/16/2014
    1401 Views
    hello,everyone.
    i want to analyze the energy consumption of the transport sector, after entered the activity level data, when i wanted to enter the energy intensity data, i met a problem. the unit should be liter per passenger-km, but i can't find it.
    Can anybody help me on this?
  • Taylor Binnington 10/17/2014
    1400 Views
    Hi Zhaojun,
    In an activity analysis, the units which are assigned to the Final Energy Intensity of a demand technology are those of 'energy per unit of activity'. However, the denominator used for these units is fixed by Activity Level variable.
    Ensure that the Activity Level units are set to passenger-km (which is found under the 'Transport' section of the units selector), and then select 'Liter' for your Final Energy Intensity. Notice that the 'per passenger-km' will automatically be appended to these units.
    If you aren't able to find the unit 'Liter', make sure that the fuel you have selected for the branch can be expressed using liters. A common mistake is to select (accidentally) a fuel such as electricity, which cannot be quantified by liters.
