• 275 views | 2 messages Discussion: LEAP
    Topic: Command import from Excel - Failure Subscribe | Previous | Next
  • Larissa Santos 11/11/2014
    1435 Views
    Dear all,
    I'm not able to run the command to import data from excel in any version of LEAP, including the latest.
    I did the procedure of creating the template LEAP, then I export to Excel and when I try to return that data for LEAP, nothing happens.
    I would like to join several sectors of the economy modeled in separate files in one leap file.
    I would appreciate any kind of help
    Larissa Albino
  • Taylor Binnington 11/12/2014
    1433 Views
    Hi Larissa,
    Sorry to hear of your troubles. A few additional questions:
    1) You mention that you would like to join several sectors from different files into a single LEAP model. Did you create the Excel template using the same LEAP file which you will be using as your single, multi-sector model?
    2) What are the options which you select when beginning the import procedure? i.e. which option do you select for 'Import expressions as:', and have you checked any of the other boxes?
    3) Which version of Windows and which version of Excel do you have installed?
    Also, if you are given any error message or dialog box, please describe its contents or post an image to this thread. Thanks very much!
