• 535 views | 4 messages Discussion: LEAP
    Topic: Creating Life-cycle profiles transportation exercise Subscribe | Previous | Next
  • Alvaro Corral Naveda 12/15/2014
    1349 Views
    I have already downloaded the LEAP version 2014. I re did the transport exercise. When I created a new profile using an exponential curve the %values are not the same as in the original exercise. Also, when I open the original exercise to compare the values and put the mouse in the constant value box and press "enter", all the %values change.
    I am sending a pdf document where it can be seen what i have previously mentioned.
    Attachments:  lifecycle transport.pdf [7]
  • Taylor Binnington 12/18/2014
    1348 Views
    Hi Alvaro,
    I am able to reproduce this issue, and see what you mean. That you very much for pointing it out to us!
    I'll look into it in more detail, which may necessitate either a small change to LEAP or a change to the online training materials. I'll respond to this thread once the problem is addressed.
    Thank you,
  • Alvaro Corral Naveda 1/6/2015
    1144 Views
    Taylor,
    Thank you very much for your help. When do you think this issue would be solved?
    P.S. By the way happy new year.
  • Taylor Binnington 3/21/2015
    1140 Views
    This problem has been resolved in the latest version of LEAP. Please select Help: Check for Updates to download it.
    All the best,
