• 330 views | 3 messages Discussion: LEAP
    Topic: Transmission and Distribution - Greyed properties Subscribe | Previous | Next
  • James Marett 1/13/2015
    1274 Views
    1. I am not able to enter Simple non-dispatched.... to T&D Properties (all areas except costs are greyed) in any scenario.
    2. Conceptually, T&D are losses between production site (power plant) and end-user (consumer) correct? This would be most applicable in electricity transmissions, pipelines, ... but not for wood fuels, charcoal. Conceptually correct?
  • Taylor Binnington 1/13/2015
    1273 Views
    Hi James,
    1. The option to check on/off "Simple non-dispatched module...", found in the properties of a Transformation module, cannot be changed once the module is created. This means that in order to change a module type from a simple to a non-simple (dispatched) module (or vice versa), you will need to recreate the module.
    2. You're right to say that T&D (Transmission and Distribution) losses, as LEAP sees them, are losses incurred between a producer and consumer. This usually means that this Transformation module appears at the very top of your Transformation branches. Though users often represent gas leakage, electricity losses (etc) in a T&D module, you may include losses of any fuel type you wish. These losses may include average biofuel losses to and from market, non-technical losses (i.e. theft), or wasted primary biofuel products leftover after a harvest - anything you wish to represent in your model.
  • James Marett 1/14/2015
    1271 Views
    Great. Thank you for quick and insightful reply. James
