• 704 views | 5 messages Discussion: LEAP
    Topic: Training Exercise 1.5.1 - can not view emission results in graph form Subscribe | Previous | Next
  • Ravita Prasad 1/21/2015
    1275 Views
    Hi
    I have done exercise 1.5 where links are created. I have checked with Freedonia the links which I created and it matches. However, when I go to Results View and click on "New Freedonia" the graph which I see is Demand: Energy Demand Final Units.
    Appreciate your assistance to getting the correct graph.
    Ravita
  • Taylor Binnington 1/23/2015
    1274 Views
    Hi Ravita,
    To view the graph shown on page 30 of our training materials (www.energycommunity.org/documents/LEAPTrainingExerciseEnglish2014.pdf), make sure you select the result category Environment: One Hundred Year Global Warming Potential.
  • Ravita Prasad 1/23/2015
    1269 Views
    Hi Taylor
    Thank your for the information. However, when I go to Results, all I see is Demand, Transformation, Resources, and Data Variables. There is no environment. How do I get environment in my result?
    Ravita
    1268 Views
    Hi Ravita,
    Have a look at this forum thread for a potential solution:
    http://www.energycommunity.org/default.asp?action=9&read=3124&fid=22
    Note that the issue described in the above thread has been solved in recent versions of LEAP. Make sure you're using the most up-to-date version, which you can do by clicking Help: Check for Updates, from LEAP's main menu.
  • Ravita Prasad 1/25/2015
    1255 Views
    Hi Taylor
    Thank you. I am now able to see environment results.
    Regards
    Ravita
