• 287 views | 2 messages Discussion: LEAP
    Topic: Energy demand primary units Subscribe | Previous | Next
  • Christine Wennerberg 5/31/2015
    1082 Views
    What is needed to display "Energy demand (primary options)" in the results view? I only have the option "Energy demand (final units")
  • Taylor Binnington 5/31/2015
    1081 Views
    Hi Christine,
    There are two different results which may answer your question.
    To view the total primary energy requirements of your whole area, you would select Resources: Primary Requirements.
    http://www.energycommunity.org/WebHelpPro/Results_Categories/Resource_Primary_Requirements.htm
    If you want the primary energy which is allocated only to demand branches, you'll need to enable that result (which is, by default, not calculated). In Analysis view, select General: Results Variables to Save, and choose Energy Demand Primary Units. In Results view, you'll then be able to view primary results.
    http://www.energycommunity.org/WebHelpPro/Results_Categories/Primary_Requirements.htm
