• 466 views | 3 messages Discussion: LEAP
    Topic: Bad Load Shape - 0% in Transformation Module Subscribe | Previous | Next
  • Camella Bailey 6/23/2015
    1021 Views
    Hi Taylor
    I am getting the attached error. 'Bad Load Shape 0% in Tranformation Module'. I seem to be missing where to enter a value.
    Can you please look at for me? See the attached err:
    Kind regards
    Camella
    Attachments:  LEAP Error, Bad Load Shape.pdf [5]
  • Taylor Binnington 6/23/2015
    1019 Views
    Hi Camella,
    This means that the values you have entered for your system load curve (defined as a Yearly Shape) are equal to zero. You need to ensure that you have correctly entered data into the yearly shape, which you assign as the load curve to your transformation module.
    1018 Views
    I got it :). Thank you Taylor.
    Kind regards
    Camella
