• 318 views | 2 messages Discussion: LEAP
    Topic: Difference between running cost in LEAP and least cost in osemosys Subscribe | Previous | Next
  • Mohd hafdzuan Adzmi 7/14/2015
    969 Views
    Hi everyone,
    I have different results when it comes to using running cost and also optimization (osemosys). I didn't include any external cost/emission cap and all other costs assumption remain the same.
    The running cost dispatches and build the cheapest plant and i think osemosys also do the same but why did it show different result? I observe that osemosys's capacity mix are more diversified than using the running cost feature.
    Any feedback is most welcome.
    Thank you
    Mohd Adzmi
  • Taylor Binnington 7/16/2015
    968 Views
    Hi Mohd,
    Actually, the RunningCost dispatch rule does not instruct LEAP to construct new capacity - it is used for process dispatch only. Capacity expansion is handled by the processes which you enter in the Endogenous Capacity variable:
    http://www.energycommunity.org/WebHelpPro/Transformation/Endogenous_Capacityu_Expansion_Calculations.htm
    With OSeMOSYS, you can allow LEAP to conduct a module-wide least-cost optimization for both process dispatch *and* capacity expansion, finding the lowest net present value of all future capacity and running costs for the transformation module.
    http://www.energycommunity.org/WebHelpPro/Optimization/OptimizationIntroduction.htm
