• 767 views | 6 messages Discussion: LEAP
    Topic: error: Last growth year parameter must be before the first scenario year Subscribe | Previous | Next
  • Barış Sanlı 8/3/2015
    960 Views
    I recently downloaded latest LEAP and Turkey started data
    When I run it using no changes, it just keeps giving this error. Any suggestions?
  • Taylor Binnington 8/4/2015
    957 Views
    Hi Baris,
    Our national starter data sets have not been updated for compatibility with the latest version of LEAP, and so they require some manual changes in order to work properly.
    One of these changes involves the second argument which is passed to the "HistoricalGrowth()" function. This function requires a year *before* the first scenario year, and so cannot be equal to "FirstScenarioYear". See our help page on the HistoricalGrowth() function for some context:
    http://www.energycommunity.org/WebHelpPro/Expressions/HistoricalGrowth.htm
    There are several ways you can change this throughout your LEAP model. The fastest would be to
    1) Export-to-Excel the variables in which this problem occurs,
    http://www.energycommunity.org/WebHelpPro/Supporting_Screens/Export_to_Excel.htm
    2) Make the necessary change in Excel to the variables you want, by searching for "FirstScenarioYear" and replacing with "FirstScenarioYear-1",
    3) Import the adjusted expression back into LEAP.
    http://www.energycommunity.org/WebHelpPro/Supporting_Screens/ImportFromExcel.htm
    I'm happy to provide additional clarification on any of these steps in necessary, but would recommend that you first experiment with LEAP's import/export to Excel capabilities on your own, first.
  • Barış Sanlı 8/4/2015
    955 Views
    Unfortunately it keeps crashing with error while importing from Excel
    953 Views
    Baris,
    Which version of LEAP are you using? Can you also please provide clear steps for reproducing the error, as well as full details about what the error is? This includes a careful description of exactly when the error appears, and preferably a screenshot of the error message itself.
    Thank you,
    952 Views
    Version: 2014.0.1.29
    1. Export everything from LEAP to Excel
    2. Do not close the Excel window and Find&Replace FirstScenarioYear with FirstScenarioYear-1
    3. Import from Excel and it crashes... I mailed you the crash
    Error: Excel cell L378 (Growth(Constrain(HistoricalGrowth(Key\Other Params\FirstShareYear,
    FirstScenarioYear-1), -Key\Constraints\MaxShareGrow[rate], Key\Constraints\MaxShareGrow[rate]))) is
    not a valid LEAP expression.
    945 Views
    This problem was resolved over email.
