• 319 views | 2 messages Discussion: LEAP
    Topic: Heat Rate for renewable energy power plant Subscribe | Previous | Next
  • Rahmat Al hasibi 9/14/2015
    789 Views
    Dear Taylor,
    efficiency for renewable energy power plant can be easily accommodated using 100% efficiency. is there a way to use heat rate as an efficiency parameter for renewable energy power plant? (I got an error message when I used zero value)
    Thank you very much.
  • Taylor Binnington 9/15/2015
    787 Views
    Hi Rahmat,
    You may choose to enter efficiency data as either an efficiency (0 - 100%) or a heat rate (greater than 3.6 GJ input/MWh output, which corresponds to the 100% efficiency limit). The setting can be found in the transformation module's properties screen.
    However, the setting takes effect for all technologies in the module - this means that you cannot specify a heat rate for some power plants and an efficiency parameter for others.
