• 402 views | 3 messages Discussion: LEAP
    Topic: RegionValue and time sliced variables Subscribe | Previous | Next
  • Randall Spalding-Fecher 10/21/2015
    669 Views
    I am trying to use RegionValue to refer to a time sliced variable (maximum availability) in another region, which is, in turn, read from an excel file. I used "RegionValue(Zambia)" for the region Zimbabwe, but the values under Zimbabwe are all zero (even though the Zambia region has correct values). Is there a problem using RegionValue with a time sliced parameter?
  • Taylor Binnington 10/22/2015
    668 Views
    Hi Randall,
    Hm - I can't reproduce this by reading time slice values into Maximum Availability from an Excel range, and then referencing that value using the RegionValue() function. Have you tried selecting Area: Force Refresh of Excel Links?
    If you sent me a trimmed-down version of your model (perhaps with only the Zambia and Zimbabwe regions) I'll have a look at it.
  • Randall Spalding-Fecher 10/27/2015
    642 Views
    Thank you - I will see if I can scale it down.
