• 770 views | 6 messages Discussion: LEAP
    Topic: Error in LEAP 2015 Subscribe | Previous | Next
  • Tanya Potapkina 11/8/2015
    722 Views
    Hello.
    I had a model in version 2014, now I downloaded a new one (2015). And I can't run the model - there is an error: cannot filter result of type "pollutant loading" on dimension "effects".
    I don't calculate any environmental effects.
    Why I have it?
    Tanya
  • Charlie Heaps 11/8/2015
    707 Views
    Sorry for the problems. I am working on a fix for this, which will be ready very soon, but in the meantime, please disable the writing of Environmental results. Please do the following:
    1. In General: Results to Save, uncheck all of the environmental results variables.
    2. In General: Basic Parameters: Scope & Scale, disable Energy Sector and Non Energy Sector Effect Loadings
    688 Views
    I already tried it. Still does not work.
    Tanya
  • Charlie Heaps 11/11/2015
    680 Views
    Hi Tanya,
    This issue should now be fixed in LEAP 2015.0.8. Please can you download that? Sorry for the problems and thanks for your patience.
    Please let me know if the problem is not solved.
  • Tanya Potapkina 11/12/2015
    661 Views
    Thank You :) Now it works.
    But You know, another problem now is with results:
    I can see the requirements and output fuels ( I have there natural gas turbine), but when I want to check the capacity, it does not show me anything (nat. gas turbine as 0).
    Before I did not have this problem.
  • Taylor Binnington 11/13/2015
    660 Views
    Hi Tanya,
    Are you sure that you've specified capacities for the transformation module, for which you are trying to view capacity results? You can check this by right-clicking on the module in the Analysis view, and selecting 'Properties'. This will give you the option to enable/disable capacity information for all of the module's processes.
    If this doesn't address your problem, please provide a careful description of the problem together with a list of steps for reproducing it.
    Take care,
