• 982 views | 7 messages Discussion: LEAP
    Topic: Time series wizard Subscribe | Previous | Next
  • Josu Markina 1/4/2016
    551 Views
    Can I select two different ranges in an Excel sheet in which the first row contains data years and its population data in the second row?
    I don´t know how to write in the range blank.
    Josu Markina
  • Taylor Binnington 1/4/2016
    550 Views
    Hi Josu,
    You may specify year and value data pairs as the argument to LEAP's Interp() function, by including the Excel range. Have a look at this help page:
    http://www.energycommunity.org/WebHelpPro/Expressions/Excel_Ranges.htm
    Good luck,
  • Josu Markina 1/5/2016
    538 Views
    I created an excel spreadsheet with three separete ranges, containing the years and the data. I did it this way to fit into a page. Is there any possibility to solve it?
    Thanks.
  • Taylor Binnington 1/6/2016
    535 Views
    Josu,
    I'm not sure I understand why you have three separate ranges. Can you explain how the Interp() function, mentioned in my previous post, will not work?
  • Josu Markina 1/7/2016
    529 Views
    Sorry Taylor,
    I`ll try to explain better.
    There are the following ranges in the spreadsheet:
    1. B1:N2
    2. B4:N5
    3. B7:L8
    I could change the format of that page if necessary but I´d like to do
    this way.
    Thanks
  • Taylor Binnington 1/7/2016
    528 Views
    Hi Josu,
    I would recommend that you format your data in a way most compatible with LEAP. A clean way to do this is to create a "Summary" worksheet in Excel that gathers data from the rest of your workbook and presents it in a way that is simple for LEAP to read.
  • Josu Markina 1/8/2016
    524 Views
    Thanks Taylor.
    Josu
