• 678 views | 2 messages Discussion: LEAP
    Topic: Could not reach LEAP server! Subscribe | Previous | Next
  • Baihe Gu 7/26/2016
    Today I registered my copy of LEAP, after I entered the LEAP registration code, and clicked "submit" button, an error came out. Which said: Could not reach leap server. Error: HTTP/1.1 302 object moved.
    Are there any one know how to do with this problem?
    Thanks a lot!
  • Taylor Binnington 7/27/2016
    Hi Baihe,
    Sorry you're experiencing this problem - actually we're aware of the issue and are actively working to fix it. In the meantime, you may "Skip" this registration step and then select Help: Register (not Register Online) from LEAP's main menu. Enter your registration information in the screen that appears and click okay. You should see a dialog that says "Thank you for registering". If a second screen appears asking you to enter your registration information again, simply click "Skip".
    We'll keep you informed when the problem is resolved.
    UPDATE 7/29/2016: This problem is now resolved. Please download and install the latest version of LEAP.
