• 1207 views | 7 messages Discussion: LEAP
    Topic: How to add off-grid power systems in Electricity Generation module Subscribe | Previous | Next
  • Ravita Prasad 8/22/2016
    Hello
    I am trying to create an energy model for an island nation with one major utility grid supplying power to 3 main islands and other off-grid renewable and diesel electricity supplying to smaller dispersed islands. Grid electricity is provided by 135 MW of hydro power, 114 MW of diesel, 10 MW of wind and IPP from biomass with capacity of 50 MW and IPP from GCPV of 0.9 MW capacity. off-grid electricity is provided by:
    1. 1.2 MW of various solar home systems units
    2. 42 kVA various diesel generator sets
    3. 30 kW of micro-hydro schemes
    My questions are:
    1. How do I add these off-grid in electricity generation module? This electricity generation is under Transmission and distribution module which has data for grid. Do I add another module saying "off-grid electricity generation"?
    2. For Independent Power Producers their installed capacity is known but they sell only part of the generated electricity to the grid. I can add this to Electricity generation module saying XX percent is maximum availability. Is this correct way?
    Appreciate your help.
    Ravita
  • Emily Ghosh 8/24/2016
    Hi Ravita,
    1) Yes, adding a separate module for off-grid electricity will work. Note that since the transformation calculations are conducted in a top-down manner, it is important the modules are arranged in the correct order using the blue up and down arrow buttons located above the tree. For example, the off-grid electricity module may need to be placed above the T&D module if it is not subject to T&D losses. For more information on transformation calculations and ordering modules, refer to the following help page: https://www.energycommunity.org/Help/index.htm#t=Transformation%2FTransformation_Calculations.htm
    2) *UPDATED RESPONSE* If you are modeling the entire demand and supply for a system, and do not include all of the electricity generated by the suppliers (i.e. by limiting the energy produced by IPPs), there may be an overall shortfall in supply. I recommend finding a solution that still calculates all of the energy generated by the IPPs, but differentiates the portion that is sold to the grid. This may be through additional modules.
  • Ravita Prasad 8/24/2016
    Hi Emily,
    Thank you for your suggestions. Will try these. If I have any problems, then will post again.
    Ravita
  • Ravita Prasad 8/25/2016
    Hi Emily
    When I create an offgrid module above T&D module, then when viewing results, I am able to get the graph till 2040 for offgrid process. But for Electricity generation module which has grid-connected systems, I am only able to get for the current year and for future years nothing comes. Similarly, when i view Energy Balance, then electricity is imported whereas it should not. What am I doing wrong?
    Ravita
  • Emily Ghosh 8/26/2016
    Hi Ravita,
    Since the off-grid generation module is the top module under the Transformation branch, the electricity generation requirement for this module is set to the overall demand for electricity (calculated from the demand branches). It is likely that this module is producing some electricity and is importing the remaining electricity requirement because of the Shortfall Rule, which, by default, is set to "Import fuel to meet shortfall". To modify this, select the electricity branch under Output Fuels for the off-grid generation module, and go to Output Properties. Ensure that it is set to "Requirements remain unmet". This way, LEAP will pass on the remaining electricity requirements to the next module which produces electricity as its Output Fuel.
    There are a few additional ways to model this system. For example, if you know exactly which demands are for off-grid electricity, you may want to disaggregate electricity demand into both on- and off-grid electricity separately, creating a new fuel specifically for off-grid electricity. Then set the Output Fuel for the off-grid generation module to this new fuel. This allows you to have dedicated transformation modules for each type of electricity.
    Good luck and let us know if you have any further questions!
  • Hanan Ishaque 9/14/2016
    Dear Emily
    I have tried to work it out the way you suggested and disaggregated demand of industry into separate activities according to demand met by Grid and Off-Grid power supply. But I can't link the demand met by Off-Grid supply with the off-grid generation module. Thus there is no result after base year.
    e.g. for textile industry i separated 70% of activity run by Off-Grid captive power plants from the demand met by Grid. Now i don't know how to link this with captive power generation, a module created above T&D module.
    Kindly help.
    Hanan
  • Emily Ghosh 9/19/2016
    Hi Hanan,
    I apologize for the delay in responding. Note that there isn't an explicit "link" between a demand branch and supply module. A supply module attempts to meet the total demand requirement for a fuel, and not for a specific demand branch. Therefore, ensure that a new fuel is created specifically for off-grid demand by going into General:Fuels (https://www.energycommunity.org/Help/Supporting_Screens/Fuels.htm). Check that the relevant demand branches using off-grid power as well as the Output Fuel for the off-grid module are set to this new fuel.
