• 289 views | 2 messages Discussion: LEAP
    Topic: Optimization Subscribe | Previous | Next
  • Varun Gaur 8/26/2016
    I would like to know if I can use LEAP to optimize electricity supply system and thermal energy supply system (cooking energy) simultaneously, because some of the potential feed-stocks/ resources could be same for both of the supply systems.
    Thanks in advance.
  • Emily Ghosh 8/26/2016
    Hi Varun,
    LEAP's optimization capabilities work for one supply-side module at a time: for example, an electricity generation module or a heat production module. To understand this, it's worth familiarizing yourself with what is meant by a "module" in LEAP:
    LEAP cannot be used to determine least-cost solutions for more than one module at a time, which means it cannot (for example) optimally allocate resources between electricity and cooking uses. In general, LEAP's optimization routine is not sensitive to the quantity of available resources - instead, it depends on the price of the resource.
    You can find more information on optimization from the following help pages:
