• 789 views | 5 messages Discussion: LEAP
    Topic: Question about InterpYearlyShape function Subscribe | Previous | Next
  • Tae Hyun Yoo 10/6/2016
    Dear Mr./Ms.
    I have a question about InterpYearlyShape function.
    The function accepts up to ten different year/shape pairs, but I need to put more yearlyshapes into the function(20 yearlyshapes!!).
    Is there any way to resolve this problem?
    Or, Is there any plan to extend InterpYearlyShape function?
  • Emily Ghosh 10/6/2016
    If you would like to enter additional pairs, use LEAP's Interp function as follows:
    Interp(Year 1, YearlyShape(Shape 1), Year 2, YearlyShape(Shape 2) ... Year N, YearlyShape(Shape N))
    This leads to a slightly longer expression compared to using InterpYearlyShape, but does not have the same limitations.
  • Tae Hyun Yoo 10/10/2016
    Hi Emily,
    It helps a lot. We resolve the problem!
  • Tae Hyun Yoo 11/17/2016
    Hi Emily,
    I have a problem about the results of two expression.
    1) InterpYearlyShape(2014,loadshape2014, 2015,loadshape2015)
    and,
    2) Interp(2014,YearlyShape(loadshape2014),2015,YearlyShape(loadshape2015))
    #2 shows wrong Load Factor(Please check with some examples). I think it can't replace the function "InterpYearlyshape".
  • Emily Ghosh 11/28/2016
    I apologize for the very delayed response. You are correct - there appears to be an error in the calculation of the Load Factor when the Interp function is used in lieu of InterpYearlyShape. We are currently looking into a solution and will let you know on this thread when the issue is resolved.
