• 289 views | 2 messages Discussion: LEAP
    Topic: GHG Emission Problem Subscribe | Previous | Next
  • Niraj Acharya 10/18/2016
    i have given different GHGs and other pollutants in environmental loading. But my output only shows methane and nitrous oxide. Please help me in this asap.
    Thank you
  • Emily Ghosh 10/18/2016
    Hi Niraj,
    If you are looking for the emission outputs from all pollutants, go to Results View, choose Environment: All Effects from the Results Selection Box and ensure the chart legend on the right has "All Effects" selected.
    Also, the outputs seen in Results View are dependent upon the branch selected from the tree. Try selecting higher level branches, such as "Demand" or "Transformation", which shows emissions aggregated from the branches below.
    Hopefully this helps, but if you continue to have a problem, please let us know.
