• 868 views | 6 messages Discussion: LEAP
    Topic: Possible bug - "Output Fuels" transformation module disappeared Subscribe | Previous | Next
  • Matthew Davis 10/28/2016
    I have been working in one of my transformation modules (petroleum refining) and the output fuels branch has disappeared and I have not been able to get it back. This happened as I was adding processes to the module. It is not configured as a simple non-dispatched module, it has always had the output fuels branch with many fuels. As it is a multi-regional model, I would rather not re-do the module from scratch as it would be a lot of re-work. I attempted to attached a backup of the model but the file size is too large for the upload here. A solution for this would be highly appreciated.
    Thank you,
    Matt
  • Charlie Heaps 10/28/2016
    Hi Matt,
    I haven't encountered this before - but as this is a multi-region model I wonder if the branches somehow got hidden in one or more regions. Suggest you visit the Branch Visibility screen in Analysis view and toggle the visibility of the relevant module for one or more regions. That screen is accessed via a button above the tree (top left of screen). It looks like this. Please let me know if this helps (or not).
    Hi Dr. Heaps,
    I use the Branch Visibility feature extensively with my model. Unfortunately the output fuels branch is not an option to show/hide - I believe the only way to hide the output fuels is to have the module as a simple non-dispatched module, which this is not. Thank you for your help.​
    Matt
    Hi Matt - yes I realize the output fuels are not accessible on that screen (which is by design) but I was wondering if toggling the visibility of their owning module might kick the output fuels back into life. I.e. Make them visible. please try that but if it doesn't work please send me your data set (attach as .leap file and email to cheaps@sei-us.org) and I will try to fix it.
    Ok I see - I toggled the hide-show branch in all regions and it worked. I greatly appreciate the quick responses. Thank you very much.
    Matt
    Great - I will note this down as a bug though.
    C
