• 554 views | 3 messages Discussion: LEAP
    Topic: Sankey Save as .emf? Subscribe | Previous | Next
  • Rabi Vandergon 11/17/2016
    When saving charts from the Results tab, there is an option to choose Enhanced Metafile (.emf). This seems to be the best choice when needing a very high resolution image and when converting a Word document to PDF. I really like the Sankey Diagram within the Energy Balance tab. However, it can only be exported as a JPG, which has low quality compared to the .emf format. Is there a reason why this is not an option, or could this please be added in a future version?
    Thank you for your time,
    Rabi
  • Taylor Binnington 11/17/2016
    Hi Rabi,
    That's a good idea - thanks! I'll log it as a feature request.
    In the meantime, does your resolution improve if you select the "Print" option in the right panel of the Sankey Diagram view, and print directly to PDF?
    Unfortunately, printing as a PDF does not seem to be any better than the JPG export, even with max JPG export quality settings selected or turning image compression off. In the meantime, the JPG version of the export should help us tell our story. I'll look forward to an update with the .emf option and thank you for your speedy feedback!
    Rabi
