• 1114 views | 8 messages Discussion: LEAP
    Topic: Export all data to Excel from Results view? Subscribe | Previous | Next
  • Rabi Vandergon 1/17/2017
    I am curious if there is a method to export data from the Results view similar to the process of exporting from the Analysis view. In Analysis view, I can use the dropdown menu from Analysis and select "Export to Excel." This brings up a menu of options for the export. The exported data in a database-like format is useful when using an external application such as Tableau to shape, explore and analyze the data.
    I am wondering if there is a method to conduct a similar process from the Results view. This would create a similar output, but instead would contain the calculated values by year, scenarios, tags, etc. Is there a method to obtain a table-like export of multiple variables using the LEAP API?
    Thank you for your time,
    Rabi Vandergon
  • Emily Ghosh 1/18/2017
    Hi Rabi,
    The Results View does not include a batch export function like the Analysis View. However, you can definitely export the results data using the API. An example batch export script for exporting energy demand results to Excel is provided in the link below:
    You can easily modify this script for other branch types (i.e. transformation, resources), result variables, etc., through LEAP's built-in script editor. Hopefully this helps get you started, but if you need any additional help, please let us know.
  • Rabi Vandergon 1/22/2017
    Hi Emily,
    Thanks for your response! The script ran well from the link you posted and I have almost everything I need in the output in Excel. I tagged branches, and I am hoping to add the tags to the export. In addition, I am trying to change the units from gigajoules to Million BTU. I am new to VB and am using the information highlighted below. I keep getting an error message when I try running the edited script posted below. Do you have any suggestions?
    The resources I've found so far are as follows:
    • LEAP API Objects in right hand pane
    • LEAP Variables in right hand pane
    • LEAP help online - using this resource is helpful, but I am still running into errors when I try running the change below (I added 4 lines attempting tag outputs and changed units to Million BTU).
    Thanks again,
    Rabi
    ' Bulk energy demand export tool for LEAP
    ' Taylor Binnington, Stockholm Environment Institute
    ' Copyright 2015
    ' Instantiate objects
    If Not IsObject(LEAP) Then
    set LEAP = CreateObject("Leap.LEAPApplication")
    End If
    set xla = CreateObject("Excel.Application")
    dim tech_branches
    set tech_branches = CreateObject("Scripting.Dictionary")
    for each b in LEAP.Branches
    if b.Branchtype = 4 then
    tech_branches.Add b.BranchID, b.Name
    end if
    next
    xla.Visible = false
    xla.ScreenUpdating = true
    set xlw = xla.Workbooks.Add
    LEAP.Verbose = 4
    LEAP.Visible = true
    set xls = xla.sheets.add
    xls.name = "Exported from LEAP"
    ' Add headers to Excel worksheet
    r = 1
    xls.Cells(r, 1).Value = "Scenario"
    xls.Cells(r, 2).Value = "Year"
    xls.Cells(r, 3).Value = "Branch"
    xls.Cells(r, 4).Value = "Fuel"
    xls.Cells(r, 5).Value = "Value (MMBtu)"
    xls.Cells(r, 6).Value = "Tag (Name)"
    xls.Cells(r, 7).Value = "Tag (Group)"
    ' Loop through scenarios, years, branches and export final energy demand in gigajoules
    for each s in LEAP.Scenarios
    for y = LEAP.BaseYear to LEAP.EndYear
    for each key in tech_branches.keys
    r = r + 1
    xls.Cells(r, 1).Value = s
    xls.Cells(r, 2).Value = y
    xls.Cells(r, 3).Value = LEAP.Branch(key).FullName
    xls.Cells(r, 4).Value = LEAP.Branch(key).Fuel.Name
    xls.Cells(r, 5).Value = LEAP.Branch(key).Variable("Energy Demand Final Units").Value(y, "Million BTU")
    xls.Cells(r, 6).Value = LEAP.Branch(key).Tag.Name
    xls.Cells(r, 7).Value = LEAP.Branch(key).Tag.TagGroup
    next
    next
    next
    xla.screenupdating = true
    xla.visible = true
  • Taylor Binnington 1/25/2017
    Hi Rabi,
    What error message do you see? Please be sure to include this information.
    When I copy and paste your script into LEAP's Script Editor and try to run it, I also see an error (though I'm not sure if it's the same as yours):
    LEAP Automation Error, Variable.Value: Cannot access results variable: "Energy Demand Final units" in a non-result view
    To resolve this, try the modification below. Note that I've made two changes:
    1. Ensured that results have been properly calculated by changing to LEAP's Results view, and then switching back to Analysis view at the end of the script.
    2. Corrected your syntax to extract tags attached to branches. Note that there may be multiple tags assigned to branches, so the script concatenates each tags into a comma-separated list before writing into Excel. Note that I haven't taken any care to group tags with their respective tag groups - instead, in the final two columns of the output spreadsheet you'll simply find a list of all tags, and all tag groups which are associated with one or more of those tags.
    End If
    dim tech_branches
    'dim tagnames, taggroups As String
    end if
    next
    xla.Visible = false
    LEAP.Verbose = 4
    LEAP.Visible = true
    r = 1
    LEAP.ActiveView = "Results"
    r = r + 1
    for each t in LEAP.Branch(key).Tags
    tagnames = t.Name & ", " & tagnames
    taggroups = t.TagGroup.Name & ", " & taggroups
    next
    xls.Cells(r, 6).Value = tagnames
    xls.Cells(r, 7).Value = taggroups
    tagnames = ""
    taggroups = ""
    next
    next
    next
    xla.visible = true
    LEAP.ActiveView = "Analysis"
  • Rabi Vandergon 2/1/2017
    Hello Taylor,
    The modification you added worked well. To further complicate matters, we are trying to add regions to our output. My coworker modified the script (which is pasted below), but it resulted in an error when it hit line 65, which is when it starts to try and assign tags. She is not very familiar with
    scripting libraries and doesn't really understand how the tags are being assigned. She is wondering if there is a way to halt the code so we can
    see what’s happening. She mentioned other code editors have this stop feature, which might be helpful in this case. Any guidance would be much appreciated.
    Thank you for all of your help so far,
    Rabi
    set LEAP =
    End If
    set xla =
    dim tech_branches
    set tech_branches =
    String
    b.Name
    end if
    next
    xla.Visible = false
    LEAP.Verbose = 4
    LEAP.Visible = true
    LEAP"
    r = 1
    "Scenario"
    "Branch"
    "Region"
    "Fuel"
    "Value (MMBtu)"
    "Tag (Name)"
    xls.Cells(r, 8).Value =
    "Tag (Group)"
    LEAP.ActiveView =
    "Results"
    LEAP.EndYear
    for each key in
    tech_branches.keys
    for i = 1 to leap.regions.count
    r = r + 1
    LEAP.Regions(i).Name
    "Million BTU")
    for each t in
    " & tagnames
    & ", " & taggroups
    next
    xls.Cells(r, 7).Value = tagnames
    taggroups
    tagnames = ""
    taggroups = ""
    next
    next
    next
    next
    xla.visible = true
    LEAP.ActiveView =
    "Analysis"
  • Taylor Binnington 2/13/2017
    Hi Rabi, sorry for the wait.
    It's difficult to tell from your post what you mean by line 65, but I'm afraid there is no hotkey combination to break execution using LEAP's internal script editor. You can, however, call LEAP from any of your favorite Windows-based editors, though, by appropriately linking to it.
    I'd suggest inerting some print statements throughout, to make sure that correct arguments are being passed to LEAP's API functions.
    Good luck,
  • Kate Desrochers 4/4/2017
    HI Taylor and Emily,
    I'm following up on
    Rabi's code questions, working on the same issue.
    Your help was much
    appreciated but now we're running in to two issues.
    1. We were able to run the code below
      without error, however, while it was generating rows with different
      scenarios in columns (as asked in line 56), it was not actually changing
      the active scenario and providing different values. It was simply giving
      us the value for one of our scenarios over and over again. Strangely, it
      was the value for the scenario with index number "3". I have
      tried various commands to have it loop through active scenarios, but each
      of them has thrown a bug. Can you help us figure out the code to get these
      values for different scenarios (I think by setting different active
      scenarios?)
    2. When I went back to rerun the
      original, no-bug code (that changed the names of the scenarios but didn't
      change the value), the code began to throw an error: Object not a
      collection" , referring to line 50, "For each s in
      Leap.Scenarios.Count". I thought you had recently changed the object
      from "scenario" to "scenarios", but I might be wrong.
      Can you help me understand the issue here?
    Thank you very much.
    The code is pasted below. I have added line numbers, please let me know if you'd like the code without them. Additionally, you'll see that we've temporarily commented out all of our tag work-- that's something we can do with equations in excel, and we wanted to minimize the possible areas for error while trouble shooting.
    Kate
    1' ============================================
    2 ' Instantiate objects
    3' ============================================
    4 If Not IsObject(LEAP) Then
    5 set LEAP = CreateObject("Leap.LEAPApplication")
    6 End If
    7
    8 set xla = CreateObject("Excel.Application")
    9 ' ============================================
    10
    11 dim tech_branches
    12 set tech_branches = CreateObject("Scripting.Dictionary")
    13 'dim tagnames, taggroups As String
    14
    15 For i = 1 to Leap.Regions.Count
    16 Leap.Regions(i).Active = True
    17 V = Leap.Regions(i).Active
    18 tech_branches.RemoveAll
    19 for each b in LEAP.Branches
    20 if b.Branchtype = 4 then
    21 tech_branches.Add b.BranchID, b.Name
    22 end if
    23 next
    24
    25 xla.Visible = false
    26 xla.ScreenUpdating = true
    27
    28 set xlw = xla.Workbooks.Add
    29
    30 LEAP.Verbose = 4
    31 LEAP.Visible = true
    32
    33 set xls = xla.sheets.add
    34 xls.name = "Exported from LEAP"
    35
    36 ' Add headers to Excel worksheet
    37 r = 1
    38 xls.Cells(r, 1).Value = "Scenario"
    39 xls.Cells(r, 2).Value = "Year"
    40 xls.Cells(r, 3).Value = "Branch"
    41 xls.Cells(r, 4).Value = "Region"
    42 xls.Cells(r, 5).Value = "Fuel"
    43 xls.Cells(r, 6).Value = "Value (MMBtu)"
    44 xls.Cells(r, 7).Value = "Tag (Name)"
    45 xls.Cells(r, 8).Value = "Tag (Group)"
    46
    47 LEAP.ActiveView = "Results"
    48
    49 ' Loop through scenarios, years, branches and export final energy demand in gigajoules
    50 For each s in Leap.Scenarios.Count
    51 LEAP.Scenarios(s).Active = true
    52 for y = LEAP.BaseYear to LEAP.EndYear
    53 for each key in tech_branches.keys
    54
    55 r = r + 1
    56 xls.Cells(r, 1).Value = s
    57 xls.Cells(r, 2).Value = y
    58 xls.Cells(r, 3).Value = LEAP.Branch(key).FullName
    59 xls.Cells(r, 4).Value = LEAP.Regions(i).Name
    60 xls.Cells(r, 5).Value = LEAP.Branch(key).Fuel.Name
    61 xls.Cells(r, 6).Value = LEAP.Branch(key).Variable("Energy Demand Final Units").Value(y, "Million BTU")
    62
    63 'for each t in LEAP.Branch(key).Tags
    64 'tagnames = t.Name & ", " & tagnames
    65 'taggroups = t.TagGroup.Name & ", " & taggroups
    66 'next
    67
    68 'xls.Cells(r, 7).Value = tagnames
    69 'xls.Cells(r, 8).Value = taggroups
    70 'tagnames = ""
    71 'taggroups = ""
    72
    73 next
    74 next
    75 next
    76 next
    77
    78 xla.screenupdating = true
    79 xla.visible = true
    80 LEAP.ActiveView = "Analysis"
  • Emily Ghosh 12/9/2017
    For future reference, here is the final code from this thread (the issues were resolved by email). Thanks!
    End If
    dim tech_branches
    tech_branches.Add b.BranchID, b.FullName
    end if
    next
    xla.Visible = true
    LEAP.Verbose = 4
    LEAP.Visible = true
    xls.name = LEAP.Regions(i).Name
    r = 1
    For s = 2 to 4
    for y = LEAP.BaseYear to 2018
    'for y = LEAP.BaseYear to LEAP.EndYear
    for each item in tech_branches.items
    r = r + 1
    xls.Cells(r, 3).Value = LEAP.Branch(item).FullName
    xls.Cells(r, 5).Value = LEAP.Branch(item).Fuel.Name
    xls.Cells(r, 6).Value = LEAP.Branch(item).Variable("Energy Demand Final Units").Value(y, "Million BTU")
    'for each t in LEAP.Branch(item).Tags
    'next
    'tagnames = ""
    'taggroups = ""
    next
    next
    next
    next
    xla.visible = true
