• 298 views | 2 messages Discussion: LEAP
    Topic: Data trend extrapolation Subscribe | Previous | Next
  • Matthew Davis 1/20/2017
    I am wondering if there is a simple way to do the following:
    • If I have data for specified years - ex: Interp(2010,500,2020,600,2030,650)
    • and I want to extrapolate the trend outwards to a future year - ex: Interp(2010,500,2020,600,2030,650) + extrapolate the trend from 2010-2030 out to 2050
    I have searched through the built in functions and could not find one that does exactly this. The "LinDataTrend" was the closest I could find but the interpolation results are not desirable.
    I have been doing this in excel and linking the file but I would like to know if there is a way to do it in LEAP with an expression.
    Thank you,
    Matthew
  • Emily Ghosh 1/20/2017
    Hi Matthew,
    LEAP does not have a built-in function that extrapolates values into the future based on a combination of historical and future data points. However, you can specify a growth rate at the end of the Interp function to grow values after the last data year. For example:
    Interp(2010,500,2020,600,2030,650, 1.5%)
    In this case, 1.5% is the calculated annual average growth rate between 2010 and 2030.
    Hopefully this helps! If you have any other questions, just let us know.
