• 329 views | 2 messages Discussion: LEAP
    Topic: Emission constraint question Subscribe | Previous | Next
  • Bri Gibs 2/12/2017
    I would like to create an emissions cap model. It says in the manual that you can add in an emission constraint- but I must be missing something since I can't really see that option in the model.
    For example, I'd like to set an emission cap of 12,000 CO2-e. Is it possible to do this? I'm not sure where I'm going wrong.
  • Taylor Binnington 2/13/2017
    Hi Bri,
    The Annual Emissions Constraint variable is only visible if you are using LEAP to conduct least-cost optimization. The constraint would then cause LEAP to try to identify a solution within the optimized transformation module which keeps total emissions at or below the value you have set.
    For further information, please have a quick look at these links:
    http://www.energycommunity.org/WebHelpPro/Transformation/Emission_Constraint.htm
    http://www.energycommunity.org/WebHelpPro/Optimization/OptimizationIntroduction.htm
