• 540 views | 4 messages Discussion: LEAP
    Topic: The Demand Subscribe | Previous | Next
  • Sebbit Adam 2/16/2017
    Dear All
    I have been adding branch under a tree. I began with Demand, under the demand I have regions. under the regions , there rural and urban. etc..
    I wanted to add another region under the demand, It seems impossible. Does it mean that the branch i over loaded ?
    Kind Regards
    Adam
  • Taylor Binnington 2/20/2017
    Hi Adam,
    I'm not sure I understand. Are you using LEAP's "Regions" feature (http://www.energycommunity.org/WebHelpPro/Supporting_Screens/Regions.htm), or are you simply naming your demand branches after separate regions in your area?
    You should be able to add another branch directly under the top-level Demand branch by selecting the Demand branch with your mouse, and then clicking the "+" (Add Branch) button.
    If this is not helpful, can you clarify your question?
  • Sebbit Adam 2/21/2017
    Thanks . That is exactly what I did. But reached a level where I could not add any more. I cannot understand why. It sees that there is capacity which the branch can handle . I tried to delete other regions but still no change.
    Adam
  • Taylor Binnington 2/21/2017
    Hi Adam,
    I'm still not sure what you did - I listed two options in my answer. Are you a) using LEAP's regions, or b) simply adding branches under demand to represent regions?
    Please also post a screen caputre of your demand tree in LEAP.
