• 280 views | 2 messages Discussion: LEAP
    Topic: LEAP - Least Cost Optimizization Subscribe | Previous | Next
  • Asim Amjad 2/17/2017
    Hello Sir,
    I am working on LEAP - Least Cost Optimization Module. I have received an error after clicking Results. The error is attached in the form of Screenshot. Kindly guide me.
    Regards
    Asim Amjad
  • Taylor Binnington 2/20/2017
    Hi Asim,
    The problem is related to the Sulfur Dioxide (SO2) emission factor which you have added to the consumption of electricity. This emission factor is given in Kilogrammes per Kilogramme (of fuel comsumed). However, electricity has no physical density or mass from which the emissions of SO2 could be calculated. You must select a different set of units for your emission factor, such as kilogrammes per terajoule.
    A larger question: it looks like you have assigned both emissions to the consumption of feedstock fuels for electricity generation, as well as the consumptoin of electricity on the demand side of your model. Are you certain that you are not double-counting the emissions associated with electricity consumption in your model?
