• 573 views | 4 messages Discussion: LEAP
    Topic: New user - working through LeapExerciseTraining2015.pdf Subscribe | Previous | Next
  • Zita Harber 2/23/2017
    Good day,
    My results for Exercise 4, Cost Benefit Analysis differ slightly from yours. Please will you send me your energy balance for the Mitigation scenario (2010 and 2040, please) so that I can check if my balance is right.
    Zita
  • Taylor Binnington 2/24/2017
    Hi Zita, welcome to the forums.
    You can check your Freedonia model against a completed version any time you like. After saving your own model (with a name other than Freedonia), click Area: Open, and choose the pre-installed Freedonia model. Once loaded, click Area: Revert to Version and choose 4.4.0: Cost-Benefit Analysis. You can use this to refer to as necessary.
    Good luck,
  • Zita Harber 2/28/2017
    Thank you, Taylor
    Now I'm stuck on exercise 6.3.1. I don't know how to set the graph up to show cumulative social costs. And my columns for the four scenarios do not show fuel production costs. Do you know where I might have gone wrong?
    Zita
  • Taylor Binnington 3/3/2017
    Hi Zita,
    To show all types of costs, be sure that you have selected the top-level branch in your tree. This will show you all costs which arise from Demand, Transformation as well as Resources (which include fuel costs).
    To display cumulative costs in results, select the "More" option above the chart, and then choose "Cumulative Values" (instead of "Absolute Values") from the dropdown menu on the left side.
