• 227 views | 2 messages Discussion: LEAP
    Topic: Optimisation Exercise 6 Subscribe | Previous | Next
  • Zita Harber 3/1/2017
    Hi Taylor
    In your training manual I have followed the instructions to the letter but I get vastly different answers than those published in the manual. I have now Fuel Production costs in my cumulative social costs chart and for Capacity my "Wind Only" scenario gives me almost TEN TIMES more than your results. I have redone the exercise three times but no change.
    Where do I even start looking?
    Zita
  • Taylor Binnington 3/3/2017
    Hi Zita,
    You can use LEAP's results view to navigte through a set of results which will help you narrow down where you've gone awry.
    If you see Fuel Production costs, then you may "zoom in" to the Resource branches and display Social Costs by fuel (selecting All Fuels in the menu to the right of the chart). This will tell you which fuel(s) are giving rise to the nonzero fuel cost that you observe. If the cost is attributed to wind, then chances are you have incorrectly entered a fuel cost under the Resources branches for the "Wind" fuel. If the cost does not arise from wind, then you know which fuels are being required that should not be, according to the training manual instructions. You can then trace these requirements to your Electricity Generation module - for example, select Transformation: Inputs, to see which fuels or power plants are consuming fuel to generate electricity.
    This process of "tracing" fuels as they flow through your model is very useful for debugging LEAP areas.
