• 402 views | 3 messages Discussion: LEAP
    Topic: Entering cost of new transmission and distribution infrastructure Subscribe | Previous | Next
  • Kshitiz Khanal 4/12/2017
    I need to add cost of new transmission and distribution lines, but I see not space for it in Transformation branch. What do I do if I have to add cost of new transmission lines for importing electricity? In the current scenario, there is no import. In the future, import will be needed.
  • Utsavshree Rajbhandari 4/14/2017
    Dear Kshitiz,
    To add cost of transmission and distribution in your transformation module, go to properties of Transmission and Distribution module you have created and Check the Costs parameter under Types of data to include section. Then you will be able to add module cost for transformation and distribution as an externally calculated total cost or as a function of some parameters within your model. In addition, you also can assign Variable operation and maintenance cost for each technology under processes.
  • Kshitiz Khanal 4/19/2017
    Dear dai,
    Thank you for the answer. I was out of my depth. It truly helped.
    Kshitiz Khanal
