• 373 views | 2 messages Discussion: LEAP
    Topic: Fatal error: Cannot create folder "\LEAP Areas\" Subscribe | Previous | Next
  • Nicholas Gall 4/17/2017
    Hello, in attempting to open LEAP today I've received the following error message. I last had a session open on Thursday, and I shut it down and saved my work normally. No idea why this is happening.
  • Emily Ghosh 4/17/2017
    Hi Nicholas,
    It would be great if you could please provide the following information to help us diagnose the problem:
    1) Have you downloaded and installed the latest version of LEAP (version 2017.0.6.0)?
    2) Can you please send us a copy of LEAP's log file to leap@sei-us.org? The file is typically found at C:\Users\your username\AppData\Roaming\SEI\LEAP\LEAP.log
    3) Did you change the LEAP Areas pathway in Basic Params: Folders last time LEAP was used?
    4) Did you change the "\LEAP Areas" folder name or location since LEAP was closed on Thursday?
