• 496 views | 4 messages Discussion: LEAP
    Topic: error in indicators since last update Subscribe | Previous | Next
  • Oriol Travesset 5/11/2017
    I have a model with a lot of indicators. It worked correctly but now it return an error when I try to simulate. I think it could be related with the last update. I tried to revert to older versions but the problem persists. Next figure shows the error:
    I removed this indicator but a similar error appears with other indicators.
    Thank you in advance
  • Emily Ghosh 5/15/2017
    Hi Oriol,
    If you include the full path name in the first branch reference (i.e. "Transformation\Generacio electrica\Processes:Outputs by Output Fuel") this should fix the problem. If the error persists, please let us know.
  • Oriol Travesset 5/16/2017
    Thanks for your response Emily. It has fixed the problem in this indicator but it persists in other indicators which worked in older versions.
    Can I send you my leap file to explore more deeply this issue?
    Lots of thanks
  • Emily Ghosh 5/16/2017
    No problem, Oriol. Please send the file to leap@sei-us.org and I will take a look.
