• 260 views | 2 messages Discussion: LEAP
    Topic: Insert Data in Key Assumptions Subscribe | Previous | Next
  • Sandra Wendt 5/12/2017
    Good day,
    I want to create a new Data file with Scenarios. I have already insert the names of the Key Assumptions, but I am not able to insert datas in the table on the right.
    Can you tell me what I am doing wrong?
    Thank you very much in advance.
    Sandra
  • Emily Ghosh 5/15/2017
    Hi Sandra,
    Is there an error that is preventing you from entering data? If so, please describe the error in in more detail.
    Otherwise, if you are trying to enter data directly into the table, please note that this is not possible. All data must be entered as "expressions" in the Expressions box for each variable in Analysis View. For more information, the following help page describes how to build and edit expressions: https://www.energycommunity.org/Help/Concepts/Expressions.htm
    Also, if you haven't already done so, I also highly recommend completing the training exercises before starting a model in LEAP: https://www.energycommunity.org/default.asp?action=trainingmaterials
    Hopefully this helps, but please let me know if you have any more questions.
