• 780 views | 5 messages Discussion: LEAP
    Topic: optimization cost Subscribe | Previous | Next
  • Wleed Ali 5/15/2017
    hi
    my problem is when i try to get the result after entering all the required data for optimization cost but it bring me back with the following error:
    Error: Numeric error, division by zero or invalid list separator
    Can anyone help?
  • Taylor Binnington 5/19/2017
    Hi Wleed,
    Can you tell me the following pieces of information from your computer?
    1. The decimal symbol,
    2. The digit grouping symbol,
    3. The list separator.
    There are settings within your Windows operating system. Usually these are accessible under the Regions & Language menu of the Control Panel > Change Number Formats > Additional Settings (though the order of steps depends slightly on your version of Windows).
  • Wleed Ali 5/20/2017
    Dear Tylor;
    thank you very much for reply;
    the format of my computer is as following:
    The decimal symbol is dot(.)
    The digit grouping symbol is comma(,)
    The list separator is semicolon(;)
  • Taylor Binnington 5/22/2017
    Thanks, Wleed.
    If you wish to use a dot (.) decimal separator, please set your list separator to a comma (,).
    If you wish to use a comma (,) decimal separator, please set your list separator to a semi-colon(;).
  • Wleed Ali 5/23/2017
    thank you Tylor
    it works
