• 500 views | 4 messages Discussion: LEAP
    Topic: Externality Cost of NOx and SO2 Subscribe | Previous | Next
  • Asim Amjad 5/18/2017
    Hello Sir,
    Hope you will be fine. Respected sir, I want to know from where I got Externality Cost Values of NOx and SO2. I need these values for Least Cost Optimization Module.
    Waiting for your Vlauded Respond.
    Asim
  • Taylor Binnington 5/18/2017
    Hi Asim -
    Are you asking where you enter this information into LEAP? To do this, check the box next to "Environmental Externality Costs", under the Costs tab of Basic Params. You will then be able to add pollutants under the Effects branch (this will appear in your tree underneath Key Assumptions) and assign them externality costs.
  • Asim Amjad 5/21/2017
    Hello Sir,
    Respected sir, I want to know where I can found these values.
    Asim
  • Taylor Binnington 5/22/2017
    Hi Asim,
    There is no single "accepted value" for the externality cost of various pollutants. The determination of these externality costs is highly contentious, depends on many factors, and would require a review of current literature in order to understand the issues and to assign a reasonable value. I'm afraid I'm not familiar enough myself with this literature for NOx and SO2 to be able to recommend a good source.
    Since you are unsure which values to use, is it imperative that they be included in your analysis?
