• 388 views | 3 messages Discussion: LEAP
    Topic: GrowthAs Subscribe | Previous | Next
  • Barragan Escandón 5/22/2017
    I am using the function GrowthAs, I understand what it does, however the explanation of the formula is not clear. Someone has a reference or bibliographic material to review in more detail.
    Thank you
    Antonio
  • Taylor Binnington 5/22/2017
    Hi Barragan,
    I'm not sure what you mean by bibliographic material. The GrowthAs() function is a special function in LEAP which can be used to tie changes over time in one variable to changes over time in another variable. You may read about it's implementation here:
    http://www.energycommunity.org/WebHelpPro/Expressions/GrowthAs.htm
    Thank you for the prompt reply. I mean if you know literature (references such as paper or books) that supports the formula indicated in
    Http://www.energycommunity.org/WebHelpPro/Expressions/GrowthAs.htm
    regards
