• 638 views | 5 messages Discussion: LEAP
    Topic: How can I make a model to include own-use and commercial electricity generating technologies at the same time? Subscribe | Previous | Next
  • Hana Kim 5/26/2017
    As you can imagine, a number of installations of distributed energy source such as PV are for own-use. Also, small-scale CHP is increasingly used for own-use (not for sale).
    The electricity from small scale rooftop solar is not connected to the grid so there is not T&D loss, but it also conversion sector.
    Is it possible for me to set up a model including own-use and commercial generation at the same time in a model?
    If you have any examples for this case, can you provide an example of area file?
    Also, I have another question.
    how can I import data(peak load shape (%) data) from excel in the yearly shapes?
    I tried several times but I failed.
    Also I could not find detailed support from the Help menu.
    Thank you in advance.
  • Taylor Binnington 6/5/2017
    Hi Hana - sorry for the wait.
    There should not be a problem simultaneously including distributed generation and own-use. Perhaps I'm misunderstanding your question, but can you explain what you have tried in order to model both of these effects, and how this approach is not satisfactory?
    To import yearly shapes, you have two options: "Import Hourly Shape" and "Import". The first option searches for named Excel ranges (the workbook must be open) of 1x8760 or 24x365 hourly data points, imports them into a new yearly shape and then normalizes them. The second option is much simpler, and simply allows you to import a named Excel range into a pre-existing yearly shape. For this, the number of data points in Excel must be equal to the number of time-slices, since the import simply copies the data from Excel directly into LEAP.
  • Hana Kim 6/10/2017
    Dear Taylor,
    Thank you so much for your informative response. I would love to take the second approach to import data from excel file to existing yearly shape.
    When I try to import the data from excel file (for example, A2: A10), the leap gave me the message "Importing from Excel (no response)" although my laptop has quite good specifications.
    Should I set the range as follows $A$2:$A$10?
    Sorry for the silly questions.
    I could not find the answer from the leap help menu.
    Regarding the first question, I take a look at more.
  • Emily Ghosh 6/12/2017
    Hi Hana,
    To use the "Import Hourly Shape" function, you will need to name the range of cells in Excel containing the hourly data. To define a name for a cell range, refer to the following Excel help page:
    With regards to the question on setting up a model with on-site or "own-use" generation, I recommend creating a new module under the Transformation branch called "On-Site Generation" (for example), and placing this module above the T&D module using the blue up and down arrows located above the tree. The ordering of the modules dictates the sequence of the transformation calculations. For this reason, by placing the On-Site Generation module above the T&D module, it would not be subject to T&D losses. For more information on transformation calculations and ordering modules, refer to the following help page: https://www.energycommunity.org/Help/index.htm#t=Transformation%2FTransformation_Calculations.htm
    Also, there have been other threads that have discussed on-site generation, which may also be a useful resource:
    Hopefully this helps, but let us know if you have any other questions.
  • Hana Kim 6/20/2017
    Dear Emily,
    Thanks a lot!
    It really helped!!!
