• 527 views | 4 messages Discussion: LEAP
    Topic: Cumulative mitigation values from Results and Summaries tab does not match Subscribe | Previous | Next
  • Anilkumar Katta 5/30/2017
    HI,
    I am trying to run an old(from 2012) LEAP model. For the scenarios, the cumulative GHG mitigation in 'Summaries' tab are different from the cumulative GHG mitigation from "Results' tab. There is a big difference between the both. I do not have this issue with my other models.
    I would like to know why there is such a difference for that model. Please support.
    Anil
  • Taylor Binnington 6/5/2017
    Hi Anil,
    Each number in the Summary view should be recoverable from the Results view. In the Results view, are you certain that you are:
    a) Showing your cumulative emissions reduction relative to the same scenario as the Summary view?
    b) Cumulating your results over the whole scenario period, as with the Summary view?
    c) Viewing emissions from all sectors, as would be shown in the Summary view?
  • Anilkumar Katta 6/5/2017
    I have re-checked all your points. I do not see any issue with those.
    Please let me know if there is anything else I could check/try?
    Thank you
    Anil
  • Taylor Binnington 6/6/2017
    Hi Anil,
    Okay, can you provide a pair of screenshots, one showing the Summary view, and the other showing the Results view, highlighting where you think the numbers disagree in the two views? Please also provide a complete set of steps for creating each of the views.
