• 511 views | 3 messages Discussion: LEAP
    Topic: benefit of carbon capture Subscribe | Previous | Next
  • Ali Lotfi 8/10/2017
    Dear Mr/Ms
    I am trying to analyze carbon capture and storage for NGCC plants. I assumed following action:
    1. Lower emissions factors : 10 % of environmental loading in fuel branches for all emissions
    2 Higher capital cost
    3. consumption more fuels: I use auxiliary fuel
    but for benefit of carbon capture i do not know any assumption? for example for 1 ton capture 10 dollars revenue
    thanks for your attention.
  • Taylor Binnington 8/15/2017
    Hi Ali - sorry for the slow repsonse.
    First - consider carefully whether emissions of all pollutants are lowered by the same percentage. Normally CO2 emissions are drastically reduced, while other pollution controls may or may not be introduced which lower other emissions.
    Before introducing a carbon price, you'll need to decide whether you want to consider this price a true "social cost", or whether the cost is really just transferred to another part of society (i.e. government, or taxpayers, etc). When viewing the result Costs: Social Costs, LEAP displays only certain categories of costs, and you may or may not want your carbon price to be reflected in these costs. If your carbon price truly is a social cost, then you can include it by modifying the Variable O&M cost by an appropriate amount. Otherwise, you may modify the Fuel Cost variable (this appears for each of the process' feedstock fuels) appropriately to include both the fuel price and the CCS subsidy. The Fuel Cost variable does not affect LEAP's Social Cost results, though it is visible by viewing the result Costs: Module Cost Balance.
  • Alsamaoal Almoustafa 8/21/2017
    hi.
    you may need to look through the attached file. hope it will be usefull
    the following link may be usefull too: http://markets.businessinsider.com/commodities/co2-emissionsrechte
    Attachments:  2016-Synapse-CO2-Price-Forecast-66-008.pdf [10]
