• 405 views | 3 messages Discussion: LEAP
    Topic: Is it possible to dis-aggregate All Others output by output fuels in Results? Subscribe | Previous | Next
  • Ravita Prasad 8/20/2017
    Hi
    In my results for transformation, Outputs by Output fuel, I have " All others" as part of the generation process output in results view for transformation. Currently in my results i have the following branches for generation process; (i) All Others, (ii) Biomass power plant and (iii) geothermal power plant. I wanted to further split "All Others" by different generation process that were entered in analysis. I know that "All Others" contain diesel and some renewable power stations. I want to know exactly how much output is by each generation process in results. Is there someway to do this?
    Thank you for your help.
    Ravita
  • Taylor Binnington 8/23/2017
    Hi Ravita -
    Above the chart you see see a box labeled "Group". You can check/uncheck this to toggle the display of the "All Others" category.
  • Ravita Prasad 8/23/2017
    Thank you so much Taylor. This helped.
