• 565 views | 3 messages Discussion: LEAP
    Topic: Importing data from excel using the API Subscribe | Previous | Next
  • Marcelo Resende 8/27/2017
    Hi! I am trying to use LEAP's script editor to import data from a xlsx file. This data would be valid only for a specific scenario ("Reference Scenario"), so I tried to do the following:
      firstscenario_year = LEAP.FirstScenarioYear - 2
      end_year = LEAP.EndYear
      LEAP.Scenario("Reference Scenario").Active = TRUE
      Set Residential = LEAP.Branches("Demand").Children("Residential").Children("Charcoal")
      Set var_activity_level = Residential.Variable("Total Energy")
      Dim year
      result_expression = "Step("
      For year = firstscenario_year  To end_year
       if ( year > firstscenario_year ) Then
         result_expression = result_expression & ", "
       end if
       result_expression = result_expression & sheet_resultado.Cells(2,year-firstscenario_year+4).Value
       result_expression = result_expression & ", " & sheet_resultado.Cells(3,year-firstscenario_year+4).Value
      result_expression = result_expression & ")"
      var_activity_level.Expression = result_expression
    My problem is in the line in bold above. It is not selecting the scenario "Reference Scenario". In fact, LEAP is always filling the scenario I select before running this code (for example, if I am in the current accounts scenario, then data from the excel is pasted in Current Accounts, not in "Reference Scenario"). I have also tried to use LEAP.ActiveScenario = "Reference Scenario" and LEAP.ActiveScenario = LEAP.Scenarios("Reference Scenario"), with the same result.
    How can I select "Reference Scenario" and fill it with excel data?
    Thanks a lot!
  • Taylor Binnington 9/6/2017
    Hi Marcelo,
    Sorry for the trouble, and for the wait. This is indeed a problem introduced in a recent version of LEAP. For now, you will need to change scenarios manually before executing your script.
    I'll let you know via this thread when the issue is resolved.
  • Taylor Binnington 12/15/2017
    Hi - this has been resolved in version 2018.0.1.2. Please download the latest version of LEAP here
