• 966 views | 7 messages Discussion: LEAP
    Topic: Inserting quadratic equation in the BAU transportation demand Subscribe | Previous | Next
  • Boram Kim 8/28/2017
    Dear all,
    I am currently trying to find expected demand for transportation sector in seoul to 2030.
    And whilst there are many ways to do that (such as using end value, growth % etc), I'd like to specifically enter quadratic equation found from Excel (e.g. Y=34.31*x^2-25.19*x+14.571)
    Is there a way to do this?
    Many thanks
  • Taylor Binnington 9/6/2017
    Hi Boram,
    What is "x" in your equation? If x is another variable stored somewhere in the model, then you may enter the following expression:
    34.31 * (path to variable x)^2 - 25.19 * (path to variable x) + 14.571
    Variable paths in LEAP are of the form path\to\branch:variable[units]. I suggest using the Branch/Variable selection wizard to help to create the reference to your variable "x".
  • Boram Kim 3/15/2018
    actually the x variable is 'year' , the formula was found by extrapolating from the graph drawn in excel
    would it be possible to specify it as year?
    many thanks
    Boram
  • Emily Ghosh 3/15/2018
    Hi Boram,
    Yes, you can use the modeling function called "Year" which uses the year currently being evaluated in LEAP. The expression would look like this:
    34.31 * Year^2 - 25.19 * Year + 14.571
    Dear Emily
    Thanks for your advice,
    I couldn't find the ' year' option in the function list (function wizard > modelling )
    could you kindly let me know this function? (I have attached the screenshot page of LEAP, and the excel page from which I found the trend equation)
    Basically, what I'd like to do is (since I don't have enough data to perform stock analysis), i'd like to use the equation found from excel (by drawing a trend curve based on data of cars registered in Seoul from 2010 to 2017) and some how apply it in LEAP to draw a more realistic forecast graph!
    I hope the function you have mentioned would allow me to perform this!
    Many thanks
    and Best wishes
    Boram
  • Emily Ghosh 3/16/2018
    Hi Boram,
    I just tested the 'year' function and it should work.
    You are correct though, the 'year' function appears to missing from the function wizard - thank you for letting us know! We will make sure to update the function wizard accordingly. In the meantime, if you are searching for functions, a comprehensive list is also provided in the LEAP help file under the section called 'Expressions'.
  • Boram Kim 3/19/2018
    thanks alot emily!
    Do you precisely know when the update will be finished?
    best wishes
    Boram
