• 283 views | 2 messages Discussion: LEAP
    Topic: Statistical Analysis in LEAP Subscribe | Previous | Next
  • Chibulu Luo 9/3/2017
    Hello! I just had a question as I'm using LEAP for one dimension of my PhD thesis.
    What types of statistical analysis are available with the LEAP tool. For example, if I wanted to assess data sensitivity? or reliability? Are there any add-ons that can be integrated within LEAP for this type of detailed analysis of data, or would I only be able to do this once I export data to excel?
    Thank you very much.
    Lulu
  • Taylor Binnington 9/6/2017
    Hi Lulu -
    There are no built-in utilities to assist with this type of analysis. However, using LEAP's API (application programming interface) you may run the software iteratively with an ensemble of different inputs to generate an array of results, and perform whichever statistical analysis you desire on those outputs. This can be accomplished using Crystal Ball (there are some threads in the LEAP support forum on this topic which you may search) or with a custom utility, if you wish.
