• 430 views | 3 messages Discussion: LEAP
    Topic: How to use the sensitivty analysis function in LEAP Subscribe | Previous | Next
  • Nnaemeka Emodi 11/2/2017
    Some months ago, I saw an update for LEAP which includes sensitivity analysis. Can you tell me how to locate it in the LEAP model?
    My Regards
    Nnaemeka Emodi
  • Taylor Binnington 11/3/2017
    Hi Nnaemeka,
    The ability to conduct sensitivty analyses is not natively built into LEAP. However, using LEAP's API (application programming interface) you may run the software iteratively with an ensemble of different inputs to generate an array of results, and perform whichever statistical analysis you desire on those outputs. This can be accomplished using Crystal Ball (there are some threads in the LEAP support forum on this topic which you may search) or with a custom utility, if you wish.
    Here are two related threads:
    https://www.energycommunity.org/default.asp?action=9&tid=3372&fid=22
    https://www.energycommunity.org/default.asp?action=9&tid=2781&fid=22
  • Nnaemeka Emodi 11/5/2017
    Thank you, Taylor.
