• 621 views | 4 messages Discussion: LEAP
    Topic: Range Check Error Subscribe | Previous | Next
  • Maya Pasechnaya 12/2/2017
    Hello!
    I have a Range Check Error message (please see attached file) every time I press Results. The same goes for Energy Balance and Summaries. I've filled in the Analysis area with different Scenarios. What can be the problem?
    Thank you!
    Attachments:  LEAP.pdf [4]
  • Emily Ghosh 12/10/2017
    Hi Maya,
    Unfortunately, the cause of the problem is not clear from the error message. If you were unable to resolve the error, feel free to send a copy of the LEAP file for us to review. To do this, go to "Area: Backup" to create a .LEAP file, then either reply to this message and attach the file, or email it to leap@sei-us.org.
  • Emily Ghosh 12/12/2017
    Hi Maya,
    I was unable to reproduce the Range Check Error in LEAP. A error still occurs after pressing the Results button, but the causes of the error are shown. If you haven't already done so, I highly recommend upgrading to LEAP version 2018.1.2 which has several improvements, including better identification and reporting of errors. The latest version can be downloaded through the LEAP website through this link.
  • Maya Pasechnaya 1/16/2018
    Hi Emily,
    Sorry, I havent seen your answer on time. I've updated to version 2018 and it doesnt show this error any more. Thank you for the advice!
    Maya
