• 207 views | 1 messages Discussion: LEAP
    Topic: Analyzing the Stability of the Switching Power System with the Taylor Taylor Expansion Method Subscribe | Previous | Next
  • Aris Suryadi 12/4/2017
    The stability of
    the electric power system is a very important issue in efforts to maintain
    reliable electrical energy supply. Anal
    mso-ansi-language:EN" lang="EN">ysis of electric power system aims to see whether the
    condition of the system is at steady state or not, after experiencing
    interference that comes from within the system and outside the system.
    EN" lang="EN">This research applies Taylor series expansion method to aid in calculations
    using Fortran Programming Language, in which the delimitation of power system
    stability on the first swing through the investigation peak rotor angle
    generators were experiencing disturbances.
    mso-ansi-language:EN;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA" lang="EN">The
    peak value of the rotor angle investigated by observing the roots of the first
    derivative of the rotor angle with respect to time of the generators by using a
    Taylor series expansion. Limit of stability with regard to the critical
    disconnection time is the maximum value of the duration of a disturbance, if
    there is at least one positive real root of the derivative of the angle
    concerned
    Attachments:  124-137.pdf [3]
