• 327 views | 2 messages Discussion: LEAP
    Topic: Limiting the use of renewable energy resources Subscribe | Previous | Next
  • Angel Nikolaev 12/8/2017
    In LEAP, is it possible to specify a limit for the use of renewable energy resources?
    For example, a country has technical potential of 1 TWh solar thermal or wind power (or alternatively specified as 500 MW capacity).
    Is it possible to make sure that the results produced by LEAP will not exceed these amounts?
    Or the only option is trial and error?
    Angel
  • Emily Ghosh 12/11/2017
    Hi Angel,
    You can set the Maximum Built Capacity so that it does not exceed the resource yield or technical potential of a renewable resource.
    For example, if you've entered the technical potential in the Yield variable under the Resource branches, you can use this example expression to convert the yield to a capacity:
    Maximum Built Capacity = Resources\Primary\Wind:Yield[MWh] * Process Efficiency / 8760 / Maximum Availability
