Hi Nur,
The default setting for the Open to Excel feature is to open a new sheet in the current workbook. This cannot be changed.
In case you accidentally selected the "Don't ask again" checkbox in the Open Table in Excel dialog box, go to "General > Reset Prompts" to show the dialog box again and enable you to select which workbook to open the file to.
