• 1005 views | 7 messages Discussion: LEAP
    Topic: Maxi Capacity builder Subscribe | Previous | Next
  • Percy Kaela 1/13/2018
    Hai Taylor,
    I have tried to use the maximum capacity build to constrain the future plant capacities but now i am having errors has explained in the attached screen shots attached and seek your guidance .
    Attachments:  Maxi capacity response.pdf [9]
  • Taylor Binnington 1/15/2018
    Hi Percy -
    What power plants, and in what increments, are you allowing LEAP to construct using the Endogenous Capacity variable? Do you see the error warning you of the problem with endogenous capacity calculations even when you do not impose anything using the Max Built Capacity variable?
    Feel free to attach your (*.leap) model to this thread. I'm not able to see a full picture of your transformation module in the screenshots you've included.
  • Percy Kaela 1/18/2018
    Hai Taylor
    The plants are various i.e hydro, solar thermal coal,and geothermal with differing capacities.In terms of the incremental addition my assumption is that leap should add any of the future plant to meet the growth in demand until available site capacities has been used.Further, the model should export when there is excess capacity and import to meet the short fall once all available capacity has been utilized .When i do not impose capacity constraint as per site potential in max built capacity  there is no error excerpt the model attempts add to capacity which are not realistically available at site to meet the demand and returns zero import and export.
  • Taylor Binnington 2/23/2018
    Hi Percy -
    Very sorry it's taken me so long to find time to reply. From your screenshots, I'm not certain that we're seeing the effect of only one error. Are you certain that your energy demands are reasonable? Try visiting Basic Params and disabling the Transformation & Resources option, and then running for model (calculating demands only). Verify that demand is being calculated as expected, and once you're convinced, return to Basic Params to re-enable Transformation & Resources. Demand which is growing orders of magnitude too quickly is a leading cause of the error message you are seeing.
    The Maximum Built Capacity variable will affect only those processes which are added using the Endogenous Capacity variable. These endogenously-added processes will be added in order of their Build Order, adding additional blocks of endogenous capacity only if their Maximum Built Capacity variable has not yet been exceeded. I've suggest reviewing this help page.
    If there is insufficient available capacity to meet the module's output fuel requirements, then by default LEAP will import the remainder. However, this is a setting which you control, and which you'll find for each of the Output Fuel branches in the module. Have a look here. Similarly, by default LEAP will export all surplus production, but only if the Export Surplus rule has been selected.
  • Fran Lallana 9/17/2018
    I saw a response you made in which you talked about the expansion with endogenous capacity function and you suggest the use of the variable "Maximum Built Capacity".
    I never found this function so useful, to combine an endogenous expansion with limits of technical capacity in a very practical way (I always do it with functions "if" within the expression of endogenous size).
    Should I enable some configuration or property to see this variable?
    Some similar function is visible when optimizing, but I never found something like this in simulation scenarios.
    Thank you very much!
    Fran.
  • Taylor Binnington 10/4/2018
    Hi Fran -
    The Max Built Capacity variable appears if you use the left/right blue arrows to adjust the Build Order, while viewing the Endogenous Capacity variable.
    I understand your point about using conditional statements within expressions for Endogenous Capacity. I do the same thing myself quite often, and it's a perfectly good way to adjust endogenous additions over time.
  • Fran Lallana 10/5/2018
    Great Taylor!, thanks.
    I always thought this variable did not work. I will try.
    Best Regards,
    Fran.
